9 years agoCurrent Limit Exceeded
Hi All,
I am using a MAX V 5M2210ZF256 CPLD to drive a bunch of LEDs and when I try to compile my program I get the following error: "Error (169007): Current density too high in I/O bank 2 -- pins combined exceed the limit (130.0 mA) by 10.0 mA" I do understand that the current capability of the bank (bank 2) is only 130mA and my requirement exceeds it by 10mA. But in an earlier project that I have done using the MAX V 5M2210ZF324C5N CPLD I have connected LEDs to a single bank in such a way that it exceeds the current limit of the bank and successfully compiled and implemented the design. What is the reason I could successfully compile my design earlier and not now? Is there any workaround for the present problem?2 Replies
--- Quote Start --- Hi All, I am using a MAX V 5M2210ZF256 CPLD to drive a bunch of LEDs and when I try to compile my program I get the following error: "Error (169007): Current density too high in I/O bank 2 -- pins combined exceed the limit (130.0 mA) by 10.0 mA" I do understand that the current capability of the bank (bank 2) is only 130mA and my requirement exceeds it by 10mA. But in an earlier project that I have done using the MAX V 5M2210ZF324C5N CPLD I have connected LEDs to a single bank in such a way that it exceeds the current limit of the bank and successfully compiled and implemented the design. What is the reason I could successfully compile my design earlier and not now? Is there any workaround for the present problem? --- Quote End --- Hi djp, Maybe you compiled your previous design with a different Quartus version? I have seen stunts like this one before... Or maybe there exists an assignment to tell Quartus that not all your LEDs will be turned on at the same time, in a way that will keep the CPLD always healthy. Anyway, shouldn't it be a better solution just to move a few leds away from that bank and keep your CPLD working under nominal conditions? Or to introduce series resistors between the CPLD and the LEDs? - Altera_Forum
What I/O constraints are you setting for these output pins? Post the project's .qsf file for us to look at.
Cheers, Alex
