10 years agoCurly braces
Hi, I was looking through a program and found the following code {a2, a1} <= {a1, b}; I am not sure whether the program that I'm going through is written in Verilog or System Verilog. I...
10 years ago --- Quote Start --- It could be a shift operation: a2 < a1; a1 <= b; --- Quote End --- Thank you for the answer. Yes it is a shift. What I really wanted to know was why concatenation is being done on the right hand side. I figured that both on the LHS and RHS the given two registers are concatenated together (on each side) and then mapped bit by bit.
