10 years agoCurly braces
Hi, I was looking through a program and found the following code {a2, a1} <= {a1, b}; I am not sure whether the program that I'm going through is written in Verilog or System Verilog. I...
10 years ago --- Quote Start --- Hi, I was looking through a program and found the following code {a2, a1} <= {a1, b}; I am not sure whether the program that I'm going through is written in Verilog or System Verilog. I know the curly braces are used for concatenation operation in verilog, but then I don't quite follow what kind of concatenation is being done here. Also since I'm not sure whether the given snippet is in verilog or system verilog, I'm left confused with the code. Also does curly braces denote another operation in system verilog..? Thanks in advance :) --- Quote End --- It could be a shift operation: a2 < a1; a1 <= b;
