Carlhermann
4 years agoCTRL+L not working correctly - Quartus Prime 21.1.0 Build 842 Lite Edition
I installed above referenced version and unfortunately the well known "CTRL+L" shortcut to start compilation now ends in deletion of current line within the code rather starting compilation. C...
Carlhermann
4 years agoFurther update
I "googled" the shortcut and CTRL+L is used in Visual Studio (I do have that installed as well) to cut the current line and copy it to the clipboard. This seems to happen, as starting a simple editor, this line can be pasted by CTRL+V...
Don't know if this is the root cause (and if it would be, it wouldn't help as I need Visual Studio as well)
finally it looks like an issue with the text editor itself - with e.g. using CTRL+F (thus the cursor is in the "find" window), CTRL+L starts compilation.
Well - will most likely end with "win 11 is not supported yet, use on own risk" I assume
