Carlhermann
4 years agoCTRL+L not working correctly - Quartus Prime 21.1.0 Build 842 Lite Edition
I installed above referenced version and unfortunately the well known "CTRL+L" shortcut to start compilation now ends in deletion of current line within the code rather starting compilation. C...
Carlhermann
4 years agoHi,
I do as I did with earlier versions... After editing the VHDL file (with Quartus' internal text editor), I just wanted to start compilation by "CTRL+L".
Now (for syntax check) I use CTRL+K, which works...
Ok - just tried to start compilation with current window in the Quartus Software not being a source code file, but the compilation report. This worked, most likely as the report is not opened by the internal text editor?
