Carlhermann
4 years agoCTRL+L not working correctly - Quartus Prime 21.1.0 Build 842 Lite Edition
I installed above referenced version and unfortunately the well known "CTRL+L" shortcut to start compilation now ends in deletion of current line within the code rather starting compilation. C...
sstrell
4 years agoCtrl-L works fine for me. Windows 11 is not supported for Quartus officially, but I doubt at this level there would be this type of issue with it. Maybe your window focus is incorrect when you're pressing the shortcut since you say it is affecting the text editor instead of compiling the design.
