14 years ago
Cryptic Error in SOPC Componenet Editor
today, I wanted to continue a project that was sleeping on my hard drive for almost half a year. I wanted to a SPI interface to my system in SOPC. While opening, I got strange errors for all my custom components. I wanted to rebuild them all. But no matter what i do, it does not work although the vhd files I would like to create my component from have not changed since last time I created the components succesfully.
here is the error I got from SOPC. I can't figure out what is wrong or how I can solve the problem:
Info: Info: *******************************************************************
Info: Info: Running Quartus II Generate HDL Interface
Info: Info: Version 9.1 Build 350 03/24/2010 Service Pack 2 SJ Full Version
Info: Info: Copyright (C) 1991-2010 Altera Corporation. All rights reserved.
Info: Info: Your use of Altera Corporation's design tools, logic functions
Info: Info: and other software and tools, and its AMPP partner logic
Info: Info: functions, and any output files from any of the foregoing
Info: Info: (including device programming or simulation files), and any
Info: Info: associated documentation or information are expressly subject
Info: Info: to the terms and conditions of the Altera Program License
Info: Info: Subscription Agreement, Altera MegaCore Function License
Info: Info: Agreement, or other applicable license agreement, including,
Info: Info: without limitation, that your use is for the sole purpose of
Info: Info: programming logic devices manufactured by Altera and sold by
Info: Info: Altera or its authorized distributors. Please refer to the
Info: Info: applicable agreement for further details.
Info: Info: Processing started: Thu Sep 15 15:52:25 2011
Info: Info: Command: quartus_map not_a_project --generate_hdl_interface=..../User_Files/sopc_user_components_tcl/ads62_avalon_st_interface.vhd --source=....quartus/User_Files/sopc_user_components_tcl/ads62_avalon_st_interface.vhd --set=HDL_INTERFACE_OUTPUT_PATH=C:/DOKUME~1/ritter/LOKALE~1/Temp/sopc5232_4103599256526625772.dir/0003_sopcqmap/
Error: Internal Error: Sub-system: PDB, File: /quartus/db/pdb/pdb_error.cpp, Line: 158
<html>Info: pdb_id <= object_info->m_ptr_table_size
Info: Stack Trace:
Info: 0x6af4: PDB_SEGMENT_READER::xfr_ptr + 0x14 (DB_PDB)
<html>Info: 0x80162: DEV_POWER_SUPPLY_DESC_BODY::operator<< + 0x492 (DDB_DEV)
<html>Info: 0x8a2d0: DEV_BASIC_INFO_BODY::operator<< + 0x193 (DDB_DEV)
<html>Info: 0x8b474: DEV_HC_INFO_BODY::operator<< + 0x3ff (DDB_DEV)
Info: 0x3f39: PDB_OBJECT_INFO::finish_reading + 0x39 (DB_PDB)
Info: 0x37bb: PDB_SEGMENT_READER::finish_reading_all + 0x3b (DB_PDB)
Info: 0xd898: pdb_read_ptr + 0x58 (DB_PDB)
Info: 0x1304d: DEV_BASIC_INFO_BODY::~DEV_BASIC_INFO_BODY + 0x25d (DDB_DEV)
Info: 0x13300: DEV_BASIC_INFO_BODY::load_hdr_from_pdb + 0x280 (DDB_DEV)
Info: 0x4c5d: MEM_SEGMENT_INTERNAL::splay_heap + 0x14d (ccl_mem)
Info: 0xe14e: DEV_BASIC_INFO::load_data + 0x11e (DDB_DEV)
Info: 0x82c5: MEM_SEGMENT_INTERNAL::allocate + 0x95 (ccl_mem)
Info: 0x9702: MEM_SEGMENT_INTERNAL::locked_allocate + 0x62 (ccl_mem)
Info: 0x17da: DEV_FAMILY_MANAGER::test_trait_of + 0x38a (DDB_DEV)
Info: 0x26a6: DEV_FAMILY_MANAGER::get_min_temperature_of + 0x596 (DDB_DEV)
Info: 0xf182: DMGR_UTILITY::create_device + 0xd762 (DDB_DMGR)
Info:
Info: End-trace
Info:
Error: Internal Error: Sub-system: DYGR, File: /quartus/ddb/dygr/dygr_device_record_manager.cpp, Line: 225
Info: i != -1
Info: Stack Trace:
Info: 0x1174d: DMGR_UTILITY::create_device + 0xfd2d (DDB_DMGR)
Info: 0x117ca: DMGR_UTILITY::create_device + 0xfdaa (DDB_DMGR)
Info: 0x1189: LdrInitializeThunk + 0x23 (ntdll)
Info: 0x224c9: RtlDestroyEnvironment + 0x177 (ntdll)
Info: 0x1caad: IsValidLocale + 0x8ea (kernel32)
Info: 0x1cb25: ExitProcess + 0x13 (kernel32)
Info: 0x221cb: _amsg_exit + 0x74 (MSVCR90)
Info: 0x22410: _get_pgmptr + 0x195 (MSVCR90)
Info: 0x22480: _exit + 0x10 (MSVCR90)
Info: 0x17be: err_ie_abort_or_exit + 0xe (CCL_ERR)
Error: 0x2dd1f: MSG_INTERNAL_ERROR::report + 0x5f (CCL_MSG)
Error: 0x2225: err_report_internal_error + 0x15 (CCL_ERR)
Info:
Info: End-trace
Error: No modules found when analyzing ..../User_Files/sopc_user_components_tcl/ads62_avalon_st_interface.vhd.
Please do not advise me to work with a later Quartus/SOPC/QSys version. I tried versions 10 and 11 but those versions do not work for me at all. Now, it looks like I'm loosing my 9.1, too . . . . :cry:
Maik
1 Reply
    Just for information: Reinstalling Quartus solved the issue . . . .
