16 years agoCritical Warning: Synopsys Design Constraints File file not found
I’m using quartus for synthesis and place &route. I’m getting the following critical warning: " Critical Warning: Synopsys Design Constraints File file not found: 'smtif.sdc'. A Synopsys Design Constraints File is required by the TimeQuest Timing Analyzer to get proper timing constraints. Without it, the Compiler will not properly optimize the design" but I’m using quartus for synthesis too.... what does this critical warning mean? Thanks, fina.
