8 years agoCritical warning about asynchronous clock domains from same PLL
Hey there, I have an FPGA design where a part is running at 150MHz and one part is running with 75MHz (both sourced from the same PLL). So, IMHO the clocks should be synchronous. Of course...
8 years agoAs far as I see I do not have any strange settings in the PLL. I will ignore this warnings and I will see, if my design fails sometime.
Thank you for your ideas and hints :)
