8 years agoCritical warning about asynchronous clock domains from same PLL
Hey there, I have an FPGA design where a part is running at 150MHz and one part is running with 75MHz (both sourced from the same PLL). So, IMHO the clocks should be synchronous. Of course...
8 years ago --- Quote Start --- I don't know where the *pll1* is coming from, but in the compilation report under Flow Summary Quartus states that 1/4 (25%) of the PLLs are used. I also don't have any command about unrelated clocks in the sdc. You can also have a look at my other post where I did a write_sdc -expand (Result: https://pastebin.com/dhefpn2e) --- Quote End --- It is strange that the tool reports unrelated clocks. Any reason why duty cycle is 50/1 on each clock??
