8 years agoCritical warning about asynchronous clock domains from same PLL
Hey there, I have an FPGA design where a part is running at 150MHz and one part is running with 75MHz (both sourced from the same PLL). So, IMHO the clocks should be synchronous. Of course...
8 years agoThe path name refers to PLL2 then PLL1 and this may give you a clue. Normally all clocks default as related yet your warning is about unrelated clocks. I doubt you have decided on unrelated clocks in your sdc
