8 years agoCritical warning about asynchronous clock domains from same PLL
Hey there, I have an FPGA design where a part is running at 150MHz and one part is running with 75MHz (both sourced from the same PLL). So, IMHO the clocks should be synchronous. Of course...
8 years ago --- Quote Start --- if clk1 is 150MHz and clk2 is 75MHz and in phase from same PLL then they are related and you don't need synchronisers to cross domains yet you are referring to non related clocks reported so your case is not clear. --- Quote End --- Yes, they should be related but I do not know why I still get this warning. In the mean time I checked my design on the FPGA and so far it works without problems (I know, that is not a reliable solution...)
