8 years agoCritical warning about asynchronous clock domains from same PLL
Hey there, I have an FPGA design where a part is running at 150MHz and one part is running with 75MHz (both sourced from the same PLL). So, IMHO the clocks should be synchronous. Of course...
8 years ago --- Quote Start --- Hey there, I have an FPGA design where a part is running at 150MHz and one part is running with 75MHz (both sourced from the same PLL). So, IMHO the clocks should be synchronous. Of course I need to bring data from one clock domain to another clock domain and I am using a 2FF synchronizer. I already did this also in other designs (eg. MAX10) and AFAIR it worked flawlessly. Now I have a Cyclone IV-FPGA and during synthesis I get a critical warning D101: Data bits are not synchronized when transferred between asynchronous clock domains... My SDC-file has the following entries:
set_time_format -unit ns -decimal_places 3
create_clock -name {clk_ext} -period 50.000 -waveform { 0.000 25.000 }
derive_pll_clocks
derive_clock_uncertainty I think everything should work, but it isn't :-/ Has anybody an idea what is going wrong here? Thank you! Regards Mathias --- Quote End --- if clk1 is 150MHz and clk2 is 75MHz and in phase from same PLL then they are related and you don't need synchronisers to cross domains yet you are referring to non related clocks reported so your case is not clear.
