--- Quote Start ---
Below is the error information:
Error: Net "dataint[15]", which fans out to "HostCom:inst3" is connecting a Partition with logic other than a single Bidirectional pin
Error: Net is fed by "inst3~6"
Error: Net is fed by "CtrlInt:inst1|DataInt[15]"
--- Quote End ---
Hi Jerry,
I'm not sure, but I think that you can't put a tristate function in a partition. What you should try is, to put the tristate function in a separate module and the remaining part of the design in a partition.
Maybe you can post the design in the forum, so that I could habe look to it.
Kind regards
GPK
