10 years agoCreate multiple design partitions (more) easily
does anyone know of a way (using a tcl script or something) to search the Project hierarchy and create a design partition around design entities matching a given name? I have to do this in order to work around a Quartus bug with multipliers (at Altera's suggestion) but I have many such multipliers and doing it by hand in the Project Navigator window is a little cumbersome (albeit doable). I have had to repeat the manual procedure a number of times however, so some form of automation would be useful. Thanks for any suggestions, Dave2 Replies
Yes, just write a script to create the partitions. Not sure if your bigger problem will be cherry-picking relevant paths in the hierarchy? But in general, if you know the hierarchies you want, writing the script to create the partitions is was enough. - Altera_Forum
Great, thanks for the link.
