11 years agoCreate multiple 'Cores' of my design
Hi, I have a design which does some image processing. I load an input image to a large Block RAM, process it using multiple filters and output it to another block RAM. I also use smaller block rams t...
11 years agoThe cores you created will have parameters about where to get the memory initialisation file from. If you instantiate the same memory over and over they will all take the same initialisation file.
How have you created the IP? from the IP catalog or from the megawizard? did you specify the file when you created the memory or have you done it via some assignments settings?
