11 years agoCreate multiple 'Cores' of my design
Hi, I have a design which does some image processing. I load an input image to a large Block RAM, process it using multiple filters and output it to another block RAM. I also use smaller block rams t...
11 years agoa 1 port ram to store the output image doesnt make sense - it means it a write only ram, which would then imply the design has no output.
You can copy any design as many times as you like in as many ways as you want, as long as you have enough resources. We have no ideas about the design, interfaces, code or any other design specs so you'll have to start asking some better questions and post some of your code and specs.
