11 years agoCreate multiple 'Cores' of my design
Hi, I have a design which does some image processing. I load an input image to a large Block RAM, process it using multiple filters and output it to another block RAM. I also use smaller block rams t...
11 years agoYes. it's possible. As long as you have enough resources in the device. The question is if you only have clock and reset as an input, how are you loading your block ram? are you just using them as ROMs?
Pete
