VVavr
7 years ago"Create HDL Design File from Current File" is disabled if open single BDF file without currently opened Quartus project.
If I have opened Quartus project and an BDF file than I can run "File > Create/Update > Create HDL Design File from Current File...". But if there is no opened Quartus project than "Create HDL Design...
Vicky1
7 years agoHi,
Well, This behavior of Quartus tool is obvious & I think It is designed such as way like that.
Vikas Jathar
VVavr
7 years agoAs I wrote above this sounds like a bug because in my case I can do converting using command line. What Quartus GUI does is simply wrapping this command in its GUI. Therefore if it is available from command line than I think "File > Create/Update > Create HDL Design File from Current File..." should be available too.
