14 years agocreate_generated_clock
hello,
im driving a 1Hz clock out of the 50 MHz clock using divide by 25000000 counter, then I feed my design with the one hertz clock, the problem is when i try to constraint the 1Hz clock with create_generated_clock i got warnning saying that i have unconstraind Base clock which is my generated clock. how come the timequest treate a generated clock as a base clock? here is my counter architecture behavioral of mytimer24 is signal gnclk :std_logic:='0'; signal gncnt0,gncnt1 :integer range 0 to 59 :=0; signal gncnt2 :integer range 0 to 23 :=0; signal en0,en1 : std_logic; begin myclk : process(clk) variable count : integer :=0; begin if clk'event and clk='1' then count:=count + 1; if count = 25000000 then count :=0; gnclk <= not gnclk; end if; end if; end process; and here is my constraints : create_clock -name clk -period 20.000 [get_ports {clk}] derive_pll_clocks derive_clock_uncertainty create_generated_clock -name gnclk -source [get_pins {gnclk|clk}] -divide_by 50000000 [get_pins {gnclk|q}] and this is the warnning that i got when updating netlist : Warning: Node: gnclk was determined to be a clock but was found without an associated clock assignment. in the RTL i see that the gnclk (generated clock) is driven by regester gnclk clocked by the 50 MHz clock and an enable signal from a 25000000 counter im new to the FPGA and timequest, I have read Rysc Timequest userguid although its really usefull and helped me alot but it more generlized. I hope somone can help and thank you in advance.
