MINGYOU
3 years agoCrash when using count value as vector signal
Below is my code module simple_circuit(F,A): input [0:3]A: output [0:1]F; assign F[0] = A[0] || A[1]&&A[2] || A[1]&&A[3]; endmodule Then I used University Program VWF, Insert the node, and ch...
ShengN_altera
3 years agoHi,
The function worked well in older version Quartus II. Tested in Quartus II 15 and 13. Quartus II 13 is still downloadable in FPGA Software Download Center. As vwf is generally older version simulator for Quartus II. For Quartus Prime, it's recommended to use modelsim/questasim simulator for more functionality.
Sheng
- MINGYOU3 years ago
Hi, Sheng
I got it, thank you.
MINGYOU
