crash during synthesis
when I run synthesis and analysis in my project it crashes after 6min. The crash happens every time (with fresh sources and quartus project). I cannot share whole project and stack trace gives no clues where the problem could be. Please find below report:
Problem Details Error: *** Fatal Error: Segment Violation: faulting address=(nil), PC=(nil) : 0: Module: quartus_syn Stack Trace: Err Handler 0x122f8: ERR_UNWINDER_BACKTRACE::get_stack_trace(void const**, int, int, void*) + 0xe0 (ccl_err) Err Handler 0x8a1f6: msg_ie_get_call_stack(void*) + 0xc4 (ccl_msg) Err Handler 0x8ba52: MSG_INTERNAL_ERROR::report_fatal(char const*, void*, bool) + 0x40 (ccl_msg) Err Handler 0x14fd2: err_report_fatal_exception(char const*, void*, bool) + 0x6f (ccl_err) Err Handler 0x15b1c: err_sigaction_handler + 0x191 (ccl_err) System 0x12980: (pthread) End-trace Executable: quartus Comment: crash during synth System Information Platform: linux64 OS name: Ubuntu 18.04.1 OS version: 18 Quartus Prime Information Address bits: 64 Version: 22.2.0 Build: 94 Edition: Pro Edition
Hi Wija,
Update:
The fix has been ported to 23.1, and will branch to 22.4 around next week for fix.
Regarding current version you are using, I am pending reply on requesting a workaround or possibly a patch. Let me know if that is okay.
- SyafieqS
Hi Wija,
Understood. I had filed a report to the developer for further debug and this is a real bug.
I will let you know once there is any update.
- SyafieqS
Wija,
This might be taking sometime and I will let you know once there is any update from engineering.
- SyafieqS
HI Wija,
Update:
This issue is due to verific bug and developer escalated this to verific team for bug fixes.
Still pending more update and will let you know once there is any findings
- SyafieqS
Hi Wija,
Update: Developer just got the dump from Verific today that has the fix for this issue. They will test it on all their suites and have it checked in within a week. Will get back to you with findings
- SyafieqS
Hello Wija,
Are you still following this discussion? Let me know if there is any update at your end.
- PiotrWija
thank you for the update. Fix in Quartus 23.1 will be enough for me. I do not need workaround.
Piotr
