PiotrWija
4 years agocrash during synthesis
when I run synthesis and analysis in my project it crashes after 6min. The crash happens every time (with fresh sources and quartus project). I cannot share whole project and stack trace gives...
- 3 years ago
Hi Wija,
Update:
The fix has been ported to 23.1, and will branch to 22.4 around next week for fix.
Regarding current version you are using, I am pending reply on requesting a workaround or possibly a patch. Let me know if that is okay.
PiotrWija
4 years agoHi,
I can't see any correlation between my case and KDB that you send.
1. I do not use import inside modport
2. I do not have localparam which depends on other parameter in the interface
3. I checked it on Quartus 22.2 and KDB was fixed since 22.1
