PiotrWija
4 years agocrash during synthesis
when I run synthesis and analysis in my project it crashes after 6min. The crash happens every time (with fresh sources and quartus project). I cannot share whole project and stack trace gives...
- 3 years ago
Hi Wija,
Update:
The fix has been ported to 23.1, and will branch to 22.4 around next week for fix.
Regarding current version you are using, I am pending reply on requesting a workaround or possibly a patch. Let me know if that is okay.
PiotrWija
4 years agoHi,
As I wrote before its not possible to create small test case in situation where Quartus gives mi no clue what part of code is it processing. Is it possible increase verbosity, or add patch with additional logs? With that, I will try to prepare the test case.
Piotr
