16 years ago
counting input signals
hello there,
I'm quite new to the fpga world, and i have run into a problem. The idea is that I want to count incoming impulses on pin1 per second (frequency varies from 200~ to 1000hz) , and then display that number on a 7segment display.
Im using the schematic layout thing.
1.I made a counter, that converts 50Mhz onboard clock to 1Hz signal.
2.A second counter (10bit) counts the impulses on pin1, and resets when it receives aclr signal ( the 1Hz signal)
3.A latch, that allows data to flow through when it receives the same 1Hz signal. aswell as a bcd converter to display the numbers.
Now the problem is clock skew > data delay. failed paths.. why oh why does this happen. I think that quartus somehow thinks of my pin1 signals as a second clock or something. What can i do ?
    --- Quote Start ---
    Got it!
    Is there a preset element in the schematic builder for that?
    --- Quote End ---
    such elements are available. You have two choices :
    1. When you double click in your schematic a windows opens. On the left side you couls see a folder called : ....../libraries. Under the subfolder "primitives" you find a folder "storage".
    There you can select "dff" for a register and place the symbol in your schematic. When you connect the register to a bus Quartus recognice the number of register automatically.
    2. You can use the Megawizard Plug-in Manager:
    Under Tools choose "Megawizard Plug-in Manager". Under Storage choose LPM_FF and go through all the tabs. The Megawizard generates a symbol for the register. Again double click into your schematic. You will find the symbol foe the register in the folder "Projec
    t".
    Kind regards
    GPK
    Awesome, everything works! thank you so much.
    Now maybe somebody could tell me how to control a 7 segment led display? I don't understand how to select and controls pins, so that they would act as GND when I need them to?
