after modification it compile successfully but simulation result is not correct
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
--use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use ieee.std_logic_signed.all;
use ieee.numeric_std.ALL;
entity rom1 is
port(CLK:in std_logic;
totalcoeffs,totalzeros:out std_logic_vector(4 downto 0);
trailingones:out std_logic_vector(1 downto 0));
end rom1;
architecture rom of rom1 is
signal etotalcoeffs : std_logic_vector(4 downto 0) := b"00000";
signal etotalzeros : std_logic_vector(4 downto 0) := b"00000";
signal etrailingones : std_logic_vector(1 downto 0) := b"00";
signal ecgt1 : std_logic := '0';
signal vin:signed(11 downto 0);
type ar is array (0 to 15) of signed(11 downto 0);
constant memory :ar:=
("111111111111","111111111111","000100000011","000000000100",
"000000000101","000000000110","000000000111","000000001000",
"000000001001","000000001010","000000001011","000100001000",
"000100000001","000100000010","000100001000","000100001000"
begin
process(CLK)
begin
if CLK'event and CLK = '1' then
x2:for i in 1 to 16 loop
vin <= signed(memory(i-1));
if vin /= 0 then
etotalcoeffs <= etotalcoeffs + 1;
elsif vin = 1 or vin = x"FFF" then
etrailingones <= etrailingones +1;
else
etotalzeros <= etotalzeros + 1;
end if;
end loop x2;
totalzeros <= etotalzeros;
totalcoeffs <= etotalcoeffs;
if (etrailingones > 3) then
trailingones <= b"11";
else
trailingones <= etrailingones;
end if;
end if;
end process;
end rom;
