18 years ago
Correct way to use Components?
I want to use a component in my VHDL code but I'm not sure if I'm doing it correctly.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
USE ieee.std_logic_unsigned.all;
ENTITY CSA4Bit IS
	PORT (X : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
		  Y : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
		  CI: IN STD_LOGIC;
		  S : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
		  C4: OUT STD_LOGIC);
END CSA4Bit;
ARCHITECTURE Structure OF CSA4BIT IS
SIGNAL S1 : STD_LOGIC_VECTOR(3 DOWNTO 0);
SIGNAL S2 : STD_LOGIC_VECTOR(3 DOWNTO 0);
COMPONENT CLA4Bit
PORT
	A : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
    B : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
    cin: IN STD_LOGIC;
    sum : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
    cout: OUT STD_LOGIC
BEGIN
--If CI = 0
--Add with CLA with Cin of 0
--If CI = 1
--Add with CLA with Cin of 1
--Make sum = to whatever one I used
--Make C4 (the carry out) = to the carry out of whichever one I used
END Structure;
I don't have code in between BEGIN and END just comments but its complaining that there's an error near text "BEGIN"; expecting "end".
Other pertinent questions, can you use more than one component in a VHDL file? How would I do this? And also, does quartus have transmission gates so I can make a mux? (i'm not allowed to use megafunctions)
    I used to be religious about putting my entities in separate files from my architectures, then using the Emacs VHDL-mode to create me a Modelsim makefile. However, I've now moved to combined files (even with packages in them when they relate to the entity in question) and using Modelsim to create the makefile.
    For iterative compilation when debugging and I can use the "-just " option to vcom to compile only the architecture in a combined file.
    I use Synplify for synthesis, but have not had occasion to try incremental compilation with it. I'll take you word for it on Quartus though :-)
    Cheers,
    Martin
