9 years agoCordic sincos function: how to depict a fixed point number as std_logic_vector type
Hello, i want to use the Cordic sincos IPcore (https://www.altera.com/en_us/pdfs/literature/ug/ug_cordic.pdf). The input is a std_logic_vector in the range of [-pi, pi] for signed configuration...
9 years ago1. No conversion is necessary. You've already said that the IP core uses fixed point representation, so your slv constains fixed point numbers.
2. With fixed point, each bit represents an decreasing 2^n, with the value in 2s compliment format So, the MSB will be the sign bit (if signed). The integer bits (range bits) just represent standandard integers. 01 = 1, 10 = 2, 11 = 3 etc. The fraction bits represent values of 2^n where each value of N is negative, eg, if you have 4 fracrtion bits, then then 1000 = 0.5, 0100 = 0.25, 0010 = 0.125, 0001 = 0.0625 etc So the bits here represent 2^-1 downto 2^-4 etc. The more bits you have, the better the accuracy you get. This is simply just integers with a gain of 2^-N, where N is the number of fraction bits.
