Clay's avatar
Clay
8 years ago
Converting POF file to SVF file
Hello Team,
I have a POF file for programming MAX 10 IC(10M04SCU169A7G).
We need SVF file to do in-system programming .
I tried to use Quartus II 15.0 Programmer to convert POF file.
But I check in-system programming(IEEE1532) result , nothing wrong in programming but fail in verifying.
To make sure the POF file is correct , I use Usb blaster to perform programming , all pass and the product is working well.
It means that there is no issue with the POF file
I suspect the SVF file I converted is not correct.
Is there other way to convert it to SVF file?
1 Reply
