11 years agoconverting java method to vhdl
Hello ,, im facing problems converting my java code to vhdl any help ? my java code
public static int size(int index){
int size=0;
for(int t=index; t<index+9;t++)
if (Sudoku_arr...
11 years ago --- Quote Start --- What is the end goal? a straight conversion will not work in an FPGA, because VHDL is NOT software. it is a hardware description language. Have you got a circuit diagram that you expect to produce that you drew BEFORE you wrote any VHDL? This is usually the first step in digital logic design. --- Quote End --- the goal is to implement it on VHDL and I know it is not a software but this is what I need to do. I drew the datapath of my code: http://s21.postimg.org/lq0tc7zjb/image.jpg
