11 years agoconverting java method to vhdl
Hello ,, im facing problems converting my java code to vhdl any help ? my java code
public static int size(int index){
int size=0;
for(int t=index; t<index+9;t++)
if (Sudoku_arr...
11 years agoWhat is the end goal? a straight conversion will not work in an FPGA, because VHDL is NOT software. it is a hardware description language.
Have you got a circuit diagram that you expect to produce that you drew BEFORE you wrote any VHDL? This is usually the first step in digital logic design.
