10 years agoConvert Verilog Input file to VHDL
I inherited a Verilog HDL from a friend. However I do not know Verilog. I want to convert the file to VHDL format to edit the file. I opened the Verilog file, and I see the Create/Update button. Howe...
10 years agoYou can try x-hdl (http://www.x-tekcorp.com/xhdl.html) - with which I've had modest success in the past. However, it's not a polished product and, as Rysc suggested, doesn't convert some constructs correctly.
I'd suggest that, depending on your VHDL fluency, you should be able to understand the verilog constructs. There is also plenty of online help and basic tutorials that will help. Try this verilog tutorial (http://www.asic-world.com/verilog/veritut.html) site. Cheers, Alex
