10 years agoConvert Matlab Code to VHDL small example
Hi, Can some one please help out.Thanks. I am trying to convert below code to VHDL using HDL Coder but getting error. The HDL Coder Block file is also attached .Please can you have a look on...
10 years ago --- Quote Start --- try check connectivity diagnostics in configuration parameter of simulink file for 'treat bus signal as vector' and set it to error. or explicity put BusToVector. --- Quote End --- HI alex,Thanks for the reply I will check it and see if it works.Did you see the model in attached file please?
