11 years ago
Conversion IEEE 754 to BCD
Hello everybody,
I'm doing an academic work in which I have to use IEEE 754 to make some operations. I'm using the megafunction to floating point and it's working properly.
Now I need to show the results in 7 seg displays of a kit and I don't know how to do the conversion between IEEE 754 and some format that I can show in the displays. Have you any idea to help me with that?
I've already tried to use TO_INTEGER function and the conversion blocks of the megafunction, but none of them work.
Thank you!
    post the code - show us the problem you are having, it will help us to help you.
    I don't have a code. I only have a block diagram with blocks generated by the floating point megafunction. I need to convert fractionary binary numbers to show its fractionary part in integer ones.
    Example:
    0 10000000 01011010111000010100100 = 2.71
    Then the '2' is easily obtained using the conversion block from megafunction. But the fractional '71' is not coming out correctly.
    Because I need to show the decimal number '2.71' on the 7 seg displays.
    Thank you!
