9 years agoContinuous signal tap capture?
Hi, I am wondering if there is a way to continuously get data from probes in signal tap. I have explored the mex matlab signal tap functionality in a loop but I lose samples. I have brie...
9 years agoInstead of trying to overcome the limitations of the JTAG, you could make changes to how the SignalTap capture buffer is set up. Choose to capture more samples, or segment the buffer to capture repeating events. You can also use sample filtering along with these features to capture only the samples you are interested in, making more efficient use of buffer space.
