12 years agocontinuous averaging using VHDL
I have a question related to VHDL programming. I want to calculate the continuous average. My example code is:
process (clk, reset)
begin
if (reset = '1') then
state<=idle;
out-v...
12 years ago --- Quote Start --- The filter sampling rate must be exactly that of adc 12 bits data rate i.e. 19.5 KHz (if I am remember it correctly). The sampling rate of a module is the clock rate as modified by any applied clock enable. The best action is to simulate the filter on its own using the matlab model I posted and to simplify it you may inject a constant or any simple stream into both your design and matlab model and compare. They must match bitwise. --- Quote End --- @kaz Ok I will check in MATLAB as well on monday. The data sheet link for the ADC that I am using is: http://www.ti.com/lit/ds/symlink/adc122s021.pdf If you see the data sheet for ADC, I previously thought that SCLK is 312KHz and if you see the timing diagram for ADC in the data sheet, it has a burst of 16 SCLK cycles so I came up with sampling rate of 312.5KHz/16=19.5KHz. But actually i was wrong. I checked it and the SCLK is 1.25MHz which means that the data rate should be 1.25MHz/16=78.125KHz or may be I think if you see the timing diagram in the ADC data sheet, there is an extra 4 SCLK cycles before the next burst comes out which means that filter sampling rate should be 1.25MHz/20= 62.5KHz. It means my average filter block should run on clock=62.5KHz according to timing diagram in data sheet(page 6 in the data sheet). Am I right? May be then I will get the 100mA directly instead of slow increment.
