12 years agocontinuous averaging using VHDL
I have a question related to VHDL programming. I want to calculate the continuous average. My example code is:
process (clk, reset)
begin
if (reset = '1') then
state<=idle;
out-v...
12 years ago@kaz
Thanks for your answer above. Actually everything is working good for me. Now there are only two issues. The first approach that I used which is continuous averaging of example 256 samples. The ''adc_a_out'' value that I receive on my GUI increments slowly. As an example, if I am expecting value 100mA, My GUI shows 4mA, 8mA, 15mA,...... and then finally after 2 minutes I get stable 100mA value. I want to see the 100mA directly on my GUI from 'adc_a_out' instead of increment values and stabilizing after sometime. Another question is that, Can I somehow make this process fast so that I don't have to wait for 3 minutes for receiving stable 100 mA from adc_a_out. I am copying the code again that I used for testing. The clock 'clk' in the digital design below is 20 MHz. The clock for receiving ADC values on the FPGA board is 15 KHz.data_in : in std_logic_vector (31 downto 0);
type type1 is array (1 to 255) of std_logic_vector(11 downto 0);
signal stage: type1 := (others => (others => '0'));
signal sub_result: signed(12 downto 0) := (others => '0');
signal sum: signed(19 downto 0) := (others => '0');
begin
out_val=0;
elsif(rising_edge(clk)) then
case state is
when out_1 =>
if done='1' then
data_out <= addr0 & bits;
stage(1) <= data_in(11 downto 0);
for i in 2 to 255 loop
stage(i) <= stage(i-1);
end loop;
-- subtract last stage from input
sub_result <= resize(signed(data_in),13) - signed(stage(255));
-- accumulate
sum <= sum + sub_result;
adc_a_out <= std_logic_vector(sum(19 downto 8));
state <= out_2;
endif;
end process;
