12 years agocontinuous averaging using VHDL
I have a question related to VHDL programming. I want to calculate the continuous average. My example code is:
process (clk, reset)
begin
if (reset = '1') then
state<=idle;
out-v...
12 years ago@kaz
Two questions. The approach that I was using before for 32 samples, I increased that to 100 samples. I did following changes in the code:data_in : in std_logic_vector (99 downto 0);
type type1 is array (1 to 99) of std_logic_vector(11 downto 0);
signal stage: type1 := (others => (others => '0'));
signal sub_result: signed(12 downto 0) := (others => '0');
signal sum: signed(19 downto 0) := (others => '0');
begin
state<=idle;
out_val=0;
out_val_2 <= 0;
elsif(rising_edge(clk)) then
case state is
when idle =>
if req='1' then
state= out_1;
end if;
when out_1 =>
if done='1' then
data_out <= addr0 & bits;
stage(1) <= data_in(11 downto 0);
for i in 2 to 99 loop
stage(i) <= stage(i-1);
end loop;
-- subtract last stage from input
sub_result <= resize(signed(data_in),13) - signed(stage(99));
-- accumulate
sum <= sum + sub_result;
adc_a_out <= std_logic_vector(sum(19 downto 8));
avg_1 <= '1';
state <= out_2;
endif;
end case;
end if;
end process; Can you tell if the number of bits for sum and sub_result are correct for 100 samples? 2nd question is related to the block average. I changed the 1024 samples to 32 samples and then averaging 5 blocks.
signal counter : integer 0 to 31 := 0;
signal data_in_d : signed(11 downto 0) := (others => '0');
signal sum: signed(16 downto 0) := (others => '0);
signal avg : std_logic_vector (11 downto 0);
type type1 is array (1 to 3) of std_logic_vector(11 downto 0);
signal sum_new: signed(16 downto 0) := (others => '0');
begin
out_val=0;
case state is
when out_1 =>
if done='1' then
counter <= counter + 1;
data_in_d <= signed(data_in);
if counter /= 0 then
sum <= sum + data_in_d;
else
sum <= (others => '0');
avg <= std_logic_vector(sum(16 downto 5));
stage(1) <= avg(11 downto 0);
for i in 2 to 4 loop
end loop;
sub_result <= resize(signed(avg),13) - signed(stage(4));
-- accumulate
sum_new <= sum_new + sub_result;
adc_a_out <= std_logic_vector(sum_new(16 downto 5));
end if;
state <= out_2;
endif;
end process; Is the number of bits for sum and sum assignment to avg is correct?
