12 years agocontinuous averaging using VHDL
I have a question related to VHDL programming. I want to calculate the continuous average. My example code is:
process (clk, reset)
begin
if (reset = '1') then
state<=idle;
out-v...
12 years ago --- Quote Start --- @kaz You mean to do the following:
data_in : in std_logic_vector (31 downto 0);
signal sum: signed(23 downto 0) := (others => '0');
signal sum2: signed(23 downto 0) := (others => '0');
begin
state<=idle;
out_val=0;
out_val_2 <= 0;
elsif(rising_edge(clk)) then
case state is
when idle =>
if req='1' then
state= out_1;
end if;
when out_1 =>
if done='1' then
data_out <= addr0 & bits;
sum = sum - sum(22 downto 10) + data_in(11 downto 10);
adc_a_out <= std_logic_vector(sum(22 downto 11));
state <= out_2;
endif;
when out_2 =>
if done='1' then
data_out <= addr1 & bits;
sum2 = sum2 - sum2(22 downto 10) + data_in(11 downto 10);
adc_b_out <= std_logic_vector(sum2(22 downto 11));
state <= done_st;
endif;
when done_st =>
ack <='1';
state <= idle;
when others =>
state <= idle;
end case;
end if;
end process; Please correct me if I am wrong. Thanks. --- Quote End --- The sum & sum2 are themselves the average, you don't need remove the 11 LSBs from them. You can keep all 23 bits since average need not be same width as data though I don't expect the mean of a good random signed signal to be higher than data. However I did some modelling of 1024 stages and it does lose resolution badly so I suggest using this method for no more than 128 stages instead of 1024.
