12 years agocontinuous averaging using VHDL
I have a question related to VHDL programming. I want to calculate the continuous average. My example code is:
process (clk, reset)
begin
if (reset = '1') then
state<=idle;
out-v...
12 years agoCouple of comments:
Why are you appending '0' on the LSB? thats like a multiply by 2, and as it is signed, it then uses the MSB as the sign bit. I think you mean: ('0' & data_in(11 downto 0); Unless data_in is signed, then you need: (data_in(11) & data_in(11 downto 0)); And as a general comment: Why is type1 an array of std_logic_vector? why not make your life easier and make it an array of signed, then you dont need all the type conversions.
