12 years agocontinuous averaging using VHDL
I have a question related to VHDL programming. I want to calculate the continuous average. My example code is:
process (clk, reset)
begin
if (reset = '1') then
state<=idle;
out-v...
12 years ago --- Quote Start --- I have a question related to VHDL programming. I want to calculate the continuous average. My example code is:
begin
state<=idle;
out-val=0;
elsif(rising_edge(clk)) then
case state is
when idle =>
if req='1' then
state= out-1;
end if;
when out-1 =>
if done='1' then
out-val<=data-in (11 downto 0)
state <= done-st;
endif;
when done-st =>
ack <='1';
state <= idle;
when others =>
state <= idle;
end case;
end if;
end process;
On every positive edge of clock, the value of "out-val" changes. I want to continuously take the average of "out-val". I want to take average of 32 values continuously. Is there a way where I can take average of 32 values continuously till the clock is running. Kindly let me know how can I do that. You can modify the above code as well. Many Thanks, --- Quote End --- first you nee to correct your syntax (don't use dash but underscore) For running average filter, the easiest way is delay input through 32 stages. subtract last stage from input and accumulate result.
