Yamada1
3 years agoConstraints on DDR signals
It would be helpful if you could teach me how to give constraints to the DDR signal from the ADC.
The conditions are as follows.
CLK : 200MHz
DATA resolution: 14bit
Signal level: LVDS
C...
AdzimZM_Altera
3 years agoHi,
May I know which IP that you used in the design?
Can I get the timing report for the failing path?
Can you export from the timing analyzer?
Adzim
