Yamada1
3 years agoConstraints on DDR signals
It would be helpful if you could teach me how to give constraints to the DDR signal from the ADC.
The conditions are as follows.
CLK : 200MHz
DATA resolution: 14bit
Signal level: LVDS
C...
AdzimZM_Altera
3 years agoHi Sir,
Thank you for submitting your question in Intel Community.
I may need more information regarding to this issue.
Can you provide the timing analysis report here? Or can you share a design that can replicate the issue?
Also, can you provide the EMIF IP setting together with memory datasheet that you used to configure the EMIF IP?
Adzim
- Yamada13 years ago
Thank you for your response.
We are very sorry, but please refrain from providing reports.
Therefore, it would be helpful if you could teach us how to describe the constraints when performing DDR constraints instead of the numerical values listed.
We apologize for the inconvenience, but thank you.
that's all
