9 years agoConstrain SDR source-synchronous bidirectional interface
I need to interface an MAX10 to an 16-bit external memory bus of MCU. All signals are synchronous to the 100MHz internal clock of the MCU (obviously) and a 25MHz submultiple of said clock is output a...
9 years agoI've corrected the type in the clock constaints - they were correct in the original sdc.
One clarification: there is no output clock from the MAX10 to the MCU. Instead , the MCU supplies a constant 25MHz clock to which the data and control lines are synchronous both for writes (data from MCU to FPGA) and reads (data driven by FPGA).
