9 years agoConstrain SDR source-synchronous bidirectional interface
I need to interface an MAX10 to an 16-bit external memory bus of MCU. All signals are synchronous to the 100MHz internal clock of the MCU (obviously) and a 25MHz submultiple of said clock is output a...
9 years agoI don't see a generated output clock for the output interface. Using derive_pll_clocks is OK, but you still need a generated clock on the clock output port (and an associated false path for that output clock so it's not analyzed as a data path). The output delay constraints should reference this newly generated output clock, not an input clock. Also, you reference clocks named fsmc_vsck and fsmc_sck in the input/output delay constraints, but you named them just vsck and sck. Check your ignored constraints report because I'm betting it will list these as ignored.
Constraining source synchronous manually is a beast. Check out this online training and see if you're missing anything. https://www.altera.com/support/training/course.html?coursecode=ocss1000
