Hi brad,
Thanks for all your hints.
You're right, 18 ps in the worst case is not relevant for my application.
But I wish fix that just for learning how to identify and resolve some timing errors. Just for playing with sdc files and timequest analyser.
I have check in the device handbook specification for my specific io pin (assigned for mem_addr[11]) and with its clock rate and derating factor, I'm able to retreive required pulse width (3.018 ns).
This is because it's a dedicated output clock pin. For all others pins interfacing with DDR (using standard I/O pin), the minimum pulse width is 2.718 ns.
It's really strange because a dedicated output clock can not run faster than a simple standard output pin... ?!
So, before closing the subject, is there some special constraints I can apply on my mem_addr[11] pin to pass all my timing requirements ?? (I don't think so...)
Now, my simple DDR2 design is fully constraint, so I will try to make the same with my TSE - NIOS II - DDR2 design... !
I will come back later if I have more questions about timing contraints.
And yet one time, thank you very much for your answers and your rapidity.
Se you!
