12 years ago --- Quote Start --- Are you simulating or synthesizing? If you write "if count < 27000 then" the code works different? Please, place the whole vhdl code to understand it better. --- Quote End --- I guess I was synthesizing. I compiled the project, download the sof to DE0-NANO to run it. Here is the VHDL code. Thank you for the help.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY work;
ENTITY square IS
PORT
clk : IN STD_LOGIC;
vs: IN STD_LOGIC; -- vertial sync
wr_req: OUT STD_LOGIC; -- write request
data: OUT STD_LOGIC_VECTOR(7 downto 0)
END square;
ARCHITECTURE bdf_type OF square IS
constant HSYNC_PERIOD : integer := 1056; -- LCD horizontal period is 1056 clock cycles
constant HSYNC_LOW : integer := 128; -- LCD horizontal sync signal pulse width is 128 LCD clock cycles
constant H_FRONT_PORCH : integer := 64; -- Horizontal front porch = 64 pixels
constant H_BACK_PORCH : integer := 64; -- Horizontal back porch = 64 pixels
constant H_PIXELS : integer := 800; -- Horizontal display period = 800 pixels
constant VSYNC_PERIOD : integer := 666 * HSYNC_PERIOD; -- LCD vertical period is 666 horizontal line
constant VSYNC_LOW : integer := 4 * HSYNC_PERIOD; -- LCD vertical sync signal pulse width is 4 horizontal lines
constant V_FRONT_PORCH : integer := 39 * HSYNC_PERIOD; -- Vertical front porch = 39 lines
constant V_BACK_PORCH : integer := 23 * HSYNC_PERIOD; -- Vertical back porch = 23 lines
constant V_LINES : integer := 600 * HSYNC_PERIOD; -- Vertical display period = 600 lines
constant RED : STD_LOGIC_VECTOR(7 downto 0) := x"0a";
constant GREEN : STD_LOGIC_VECTOR(7 downto 0) := x"0b";
constant YELLOW : STD_LOGIC_VECTOR(7 downto 0) := x"0c";
constant BLUE : STD_LOGIC_VECTOR(7 downto 0) := x"0d";
constant PURPLE : STD_LOGIC_VECTOR(7 downto 0) := x"0e";
constant TURQUOISE : STD_LOGIC_VECTOR(7 downto 0) := x"0f";
constant WHITE : STD_LOGIC_VECTOR(7 downto 0) := x"10";
constant PIXEL_OFF : STD_LOGIC_VECTOR(7 downto 0) := x"01";
BEGIN
-- Input:
-- none
-- Clock:
-- LCDclk - LCD clock @ 10 MHz
-- Output:
-- LCDHsyncN - signal, LCD horizontal timing
-- Description:
-- This process generates LCD horizontal timing signal: 480 clock cycles high and 128 clock cycles low
PROCESS(clk, vs)
variable p_count : integer range 0 to H_PIXELS;
variable clk_count : integer := 0;
BEGIN
if rising_edge(clk) then
if vs = '0' then
-- clk_count := ((HSYNC_PERIOD * VSYNC_LOW) - 1); -- Vertical sync pulse width is 4 lines
clk_count := (1056*4) - 1; -- Vertical sync pulse width is 4 lines
wr_req <= '0';
else
clk_count := clk_count + 1;
-- if clk_count < (HSYNC_PERIOD * (VSYNC_LOW+V_BACK_PORCH)) then
if clk_count < (1056 * (4+23)) then
-- vertical blank period; do nothing
p_count := 0;
wr_req <= '0';
-- elsif clk_count < (HSYNC_PERIOD * (VSYNC_LOW+V_BACK_PORCH+1)) then
elsif clk_count < (1056 * (4+23+1)) then
-- 1st display line
-- if clk_count = (HSYNC_PERIOD * (VSYNC_LOW+V_BACK_PORCH)) then
if clk_count = (1056 * (4+23)) then
-- 1st pixel of the line
p_count := 0; -- reset pixel count
wr_req <= '1';
-- elsif clk_count < ((HSYNC_PERIOD * (VSYNC_LOW+V_BACK_PORCH)) + H_PIXELS) then
elsif clk_count < ((1056 * (4+23)) + 800) then
data <= GREEN;
wr_req <= '1';
else
wr_req <= '0';
data <= PIXEL_OFF;
end if;
else
data <= PIXEL_OFF;
wr_req <= '0';
end if;
end if;
end if;
END PROCESS;
END bdf_type;
