13 years agoConnecting DDR3 on ArriaII GX Development Kit
My design has an DDR3-Interface. Pin Assignment I copied from Referencedesign "a2gx125_qsys_pcie_gen1x4_11_0_1". Fitter Works successfully, but I get a Critical Warning. Can anyone help? Thank you in advance Critical Warning (185021): Detected external clock signal directly connected to the RAM "q_sys: u0|q_sys_cpu:cpu|q_sys_cpu_nios2_oci: the_q_sys_cpu_nios2_oci|q_sys_cpu_nios2_ocimem: the_q_sys_cpu_nios2_ocimem|q_sys_cpu_ociram_lpm_dram_bdp_component_module: q_sys_cpu_ociram_lpm_dram_bdp_component|altsyncram: the_altsyncram|altsyncram_14e2:auto_generated|q_a[0]" CLK0 port. This connection may cause unexpected memory behavior if your external clock signal violates the minimum pulse width specifications (clock high time and clock low time).
