15 years ago --- Quote Start --- Hi Folks, Thanks for your help and apologies to SLV for not actually answering your question before but you guessed correctly. I have taken your example and tried the attached, which seems to work. Is there a way defining which bits go to which (say if you have abus[15..8] connected to aport[7..0] does it always connect the highest bits together in descending order? Don't feel obliged to answer...). Thanks again for all your input. Best regards, H --- Quote End --- Hi H, You didn't indeed answer my question, but my guess was ok. To swap bit order, you can use a small simple piece of VHDL-code, as attached, including Quartus symbol file. Can also be used to split busses, or to make a bus partially constant, with some minor modifications. Consider this as my gift to the public domain :-) To be used without any warranty. Cheers, Ton
