15 years agoHi Folks,
Thanks for your help and apologies to SLV for not actually answering your question before but you guessed correctly. I have taken your example and tried the attached, which seems to work. Is there a way defining which bits go to which (say if you have abus[15..8] connected to aport[7..0] does it always connect the highest bits together in descending order? Don't feel obliged to answer...). Thanks again for all your input. Best regards, H
